Please could you take a look at the attached images and perhaps let me know your thoughts.
I have noticed when taking flats via the Skywatcher 150 ED Triplet that there is a significant circular gradient on the FITS images concentrated in the center of the image. I have not noticed this whilst taking lights only when doing flats with my LED panel. I have two ASI 294 cameras one is set up permanently on the 150 APO (Camera 1), the other is set up permanently on the 9.25 Edge HD (Camera 2). I do not know which one is the newer or older.
Thinking there was a fault on Camera 1 I changed it out with Camera 2 – its performance was the same when attached to the 150 APO in place of Camera 1. I changed back to Camera 1 and conducted an experiment adjusting the cooler settings.
When I switched the cooler OFF the problem went away but only once the sensor had warmed back up so nothing to do with current. I switched the cooler back on and starting at plus 7’C the problem reappeared. I set the camera back to plus 10’C and the gradient disappeared.
Question 1 do you think this is condensation or dew forming on the sensor ? The ambient temperature during testing was 21’C the local dewpoint from BOM Australia Perth was 12.9’C with 65% relative humidity
Question 2 why do I not see the issue when the camera is on the 9.25 edge HD ?
Question 3 why do I not notice the issue whilst collecting light frames at night, is it because of the dark sky ?
Finally, the reason I pursued this today is that I noticed speckling whist taking Mono 8 shots of the Sun yesterday via a Solar Filter with the cooler set at my normal -10’C, see Grab – image 4
Grateful if you have any solutions/thoughts ? For now I will collect flats with the cooler off and collect Solar Fits/AVI/SER with cooler off also.
