shandypaul
In your case, I would use 2 outlets from your setup:
- 1 for the AVX mount
- 1 for the ASIAir Pro -> EAF, ASI294MC-P, Dew-heater.
Your AVX most likely barely suck about 3A only in fast GoTo mode, than probably about 1A while guiding only when RA/Dec are solicited.
Dew heater should not go up to more than 2A, ASI294MC-P should be well within the 3A even with cooling at 75% (advised not to go higher, as Peltier cooler are the weak device in cams...) So if you get your -10deg or -15 deg within this 75% range, you should be plenty fine.
