I initially had problems with my 294mc and determined it was due to the USB cable. I also have a powered hub on my scope. I purchased a pair of new "high quality" cables from Monoprice, and one of them was defective. One worked fine, but the other caused the camera to drop the connection, or lock up. The same cable worked fine for other purposes, so maybe the camera is sensitive to cable quality. If you haven/t already, I suggest you try several cables. Also, don't assume the hub is ok. Try different sockets, and also try connecting the 294 directly to the computer.
