I am concerned about the initial color balance when decoding the bayer filtered image as the ASIstudio is doing.
How can I test the colorbalance?
How can I correct the color balance if it off?
Can ASISTUDIO produce eg TIF RGB output from the initial FIT file - then I can migrate the image to eg PIXINSIGHT.
Matlab can read the ZWO bayer coded FITS files - and can convert the image to RGB using demosaic. But it would be easier if ASISTUDIO did this
