1st, you need to understand your mirror position in relation to focusing.
Is it near focus (like daylight style, watching distant landscape) or near infinity focus, astro/star focus.
Then, which way does the know has to rotate (clkwise or ctr-clockwise) -> will determine if EAF will work in normal or reverse.
Then how many turns (complete revolutions) between some close objects (moon) or distant DSO -> will give you number of turns for the 60000 steps of EAF.
Easiest is then to position your EAF and allow couple of turns one way, keeping remaining range for other direction.
EAF cannot work in negative values.
So if you set it like above, depending on rotation direction you choose (normal / reverse), once in place you set it electronically to the position ( 15000 or 45000)...
You just then have to check your focusing range covers your needs....
normal/reverse may also have an impact on mirror shifting, as AF sequence is always going in same direction.
raw focus -> jump 150 steps -> move back down 30 steps increments building V curve.
Once estimated focus position known, EAF jump another 45 steps up above estimated focus position, then back down by 15 steps increment until confirmed focus position is obtained.
So chose as to ensure your mirror is shifted the right way reaching focus.
