Hi I recently updated to the ASIAIR pro and when I connect my ZWO guide and main cameras I get the message network cable disconnected then a few seconds later it says network cable connected this repeats every few seconds even though the camera still shoots but in between when the message network cable disconnected appears nothing works what is the problem
What power supply do you use? What are your ZWO cams network cable is RJ45 ethernet lan cable, nothing to do with ZWO ASI cams (USB 3.0 or 2.0) so most likely a power issue causing this... Tell us more...
Thanks Seems like it was a transformer problem.
