I was wondering if ths ASIair Pro is compatible with and can be used to operate a Meade LX200GPS telescope. If so what software and cables would I need to make it work. Any help, advice or direction will be greatly appreciated.
It is supported.
Thank you for your reply...
How do you cable connect the ASIAIR PRO to the LX200GPS/ACF? Does it connect to the Autoguider port?
PureRockets
Tech@ZWO Both of these links have expired. Do you know of a current resource to help answer this question?
