If I connect the USB cable between my ASIAir Pro and my Astrophysics Mach1GTO mount (GTOCP4), then power on the ASIAir Pro unit, it will not boot (I waited for over 2 minutes). If I unplug the cable to the mount, the ASIAir Pro will finish booting (beep) within 15-20 seconds, then I can plug the cable to the mount back into the unit and everything works fine. Also, if I leave the cable to the mount unplugged before powering on the ASI Pro, the unit will also boot normally, then I can plug the cable to the mount into the ASIAir Pro. Is this normal behavior?
