I just purchased an eaf focused with external temp probe. I'm seeing about a plus 5 deg Fahrenheit temperature error. Can this be calibrated? Also can the ascom driver be set to Fahrenheit?
Just a follow up: I removed the external temp sensor and found that the internal sensor shows a temp of +5.86C when in fact the air temp is -7.7 C
The internal sensor shows a temp of +5.86C(this is the temp of Single-Chip Microcomputer, higher is normal)
