Is it possible to buy a replacement window for the ASI174mm mini?
https://astronomy-imaging-camera.com/product/zwo-protective-window-asi-cameras
Thank you. ate there instructions how to install the window since the original is mounted in a black metal rim?
Are there instructions how to install in the metal rim that the original window is mounted?
andrewarai It's easy, just give some twist.
