I have two suggestions that I think would be useful for ASIAir users:
Stability Dither settings currently have 5 values to choose from: 0.6", 1", 2", 3", 4". I'm not sure how useful is 4" but would be happy to use something in between 0.6-1, let's say 0.8". And the reason for this request is that some of users can do better than 1" but only lucky few with hi-end mounts can pull off stable 0.6". The 0.5"-1.0" range is most desirable for astrophotographers and any tiny improvements here are welcomed. Please add 0.8" option if possible.
When you dither you can't judge you autoguiding precision anymore as dither events screw up your statistics. Could you exclude Dither event plus following "Settle Time" period from RMS error calculations? This would really help.
Thanks for considering.
