I'm a beginner and I love the program and its simplicity, which doesn't exist in any other. I am doing DSO and the program works very well without guidance (PHD2).
Therein lies the problem. I wanted to make it my default program, but when I start using guiding it just doesn't work. I use 2 zwo cameras at the same time (asimini 120mm, for guiding) and asi 6200mm. The point is that when you open the phd there is a conflict, in which this program does not recognize the mini (only the asia6200mm), and asistudio stops working and gives a crash. It's necessary to close (cause it stops to save images), but even in this situation phd e asistudio does not work with 2 zwo cameras.
Another suggestions for improvement would be to give the opportunity to use the program with another filter wheel from other brands (but the program is not even known, unfortunately), and a channel to works well with PH2, the most usefull software for guiding.
Regards
