hi I am kinda frustrated.
Just got my asiair pro. third night with no succes on imaging.
first 2 nights same thing would plate solve but than go crazy on on trying to find the target all the trials were no where close but it did slew.
Tonight it says mount is slewing yet nothing is happening. I can control the mount via asiair pro's phone app with arrows . It can control the mount via arrows however when I say go to a target than it doesnt do anything.
When I say go to home position same nothing happens.
I am not sure if this is related but I may messed the device at dark while trying to put the dslr shutter release cable's jack to the inlet ( which is right nex to power outlets) it did accidently touch the inner parts of the power outlet next to it.Nothing happened as far as I could observe but This is the only difference than the first two nights all the rest remains the same. But if I caused a short circuit or any other conflict there would be obvious malfunctioning right?
mount still slews via arrow keys
everyt other control seems to work properly
finding target was a problem before also
but know go to slew function wouldnt do anything despite the fact that app says "mount is slewing"
I am using a Meade LX85 and did try to connect every meade option at asiair pros interface ( since there is no meadelx85 Used to try meade lx200 classic
so any urgent help would be apreciated.
first How can I get the mount slewing to target again
second what do I need to do to make that target valid
thanks for taking your time to read. All help will be highly apreciated.
Best
