I have recently purchased a ASI294MM Pro Camera which was supplied with unlocked Bin1 mode.
For imaging I use MaximDL v6.21 and FocusMax v4.1.0.102 and so control the camera through the ASI ASCOM driver.
I have also used ASIStudio to control the camera using the Native ASI Driver.
In both cases the default mode is Bin1 not Bin2 as stated in the recently updated product specification.
The issue is compounded by a defect in the ASCOM driver for Bin2 mode which causes sub-frame errors where the camera control is unable to correctly calculate and render the dimensions of the sub-frame window.
The ASCOM camera driver needs to be updated to allow use of the new ASI294MM Pro cameras with unlocked Bin1 mode to operate correctly at Bin2 mode. At present Bin2 is not the default mode for the camera which is contrary to the stated product specification.
With my current imaging software and telescope setup the ASI294MM Pro is unusable at Bin2. I purchased the camera to use with 4.6um pixel size at 4144 x 2822 pixel resolution as this gives me the optimal plate scale for imaging.
