A little background on the problem. I got my ASIAir Pro back in July 2020, got my Losmandy G11 almost at the same time. They functioned flawlessly for 3-4 months. On November I decided to purchase another ASIAir Pro and a "lighter" mount (Skywatcher EQ6R Pro). I switched to the new setup (which included the new ASIAir Pro, and the Skywatcher EQ6R-Pro to get set it up, get to know it, etc (so my initial "AAP+Losmandy G11 was placed on hold for a while I tried the new arrivals for a couple of weeks) The second setup BTW performs way better at guiding that the first one with the same parameters, which I can specify if needed. After a couple of weeks I tried to come back to my first ASIAir and the Losmandy G11, and to my surprise I cannot PA and guiding is useless; I have no problems on goto function, no problem plate solving, however, the PA routine will stop constantly try after try at 8 degrees of rotation (I do now PAs with a QHY Polemaster). Later found out about another annoying issue, guiding will start after calibration, and after 5-10 seconds DEC goes haywire, and guiding just doesn't happen (7"-10" of error at least); the RA will stick around 1.0" -1.5", but the DEC just disappears off the graph... I took care of not mixing setups, to avoid any misconfigurations between the two ASIAirs, but had to try with both ASIAirs to see if the problem is prevalent in the two of them and YES, both behave similarly. I myself being a doctor, am no software/harware expert, but what I can diagnose is obviously a "recently acquired problem of communication in PA and guiding" between the AAP and the G11, which started on the latest release/update of the AAP software. Has anyone experienced similar behavior with a Losmandy G11?
