I updated the ZWO ASI camera ASCOM driver to version 6.5.16.3 (this is what it says in the driver window, it corresponds to version 6.5.1.3 on the ZWO website) together with the corresponding native driver. The native driver works well in Sharpcap. However, when I use the ASCOM driver in Sequence Generator Pro and Sharpcap, the gain can only be set between 0 and 100. I don't know what these values correspond to in relation to the full range of gain (0 to 480) for the ZWO ASI6200MM in the native driver. Is this correct or is it a bug? If it is correct, what does gain 100 in the native driver correspond to in the ASCOM driver?
I wanted to test if an older version of the ASCOM driver worked correctly (it used to work until I updated the native and ASCOM drivers to the 12/31/2020 version). Where can I download previous versions of the drivers?
Thanks,
Luca
