Hello , I have a 120MM mini that works well under windows, however under Stellarmate (Raspberry Pi4 8GB) the camera is detected but does not download any Image. I see from Google search that many solved the problem upgrading the firmware to asi120mm-compatible.iic. I can download the Firmware upgrade tool from ASI web site but I cannot find any firmware file, can you possibly point me in the right direction?
Thanks Mirko
Hello mirko compatible firmware is for the old usb2.0 cameras,including the 130MM(2.0) 120MM(2.0)etc.
120mm mini is usb 3.0 camera
addition: It works with the ASIAIR PRO
Hello, thanks for the reply. I think I have a 120mm 2.0 OEM version from Omegon ASI Studio recognizes it as 120mm Is it still possible to flash with asi120mm-compatible.iic ? (Where to download it?) thanks Mirko
asi120mm-compatible.iic is for asi120mm. You could download it from here: https://astronomy-imaging-camera.com/software-drivers in the FW Update tab
