I think that it would be very nice to have the option (check box) in the auto run sequence to abort the sequence if an error is generated (probably multiple occurrences of the same error to be safe). This would avoid potential damage to equipment e.g. I have had errors when the ASIAir is trying to plate solve after the meridian flip and it can't find the appropriate stars. So it just keeps on going looking for them.... Without intervention this will eventually expose the camera to daylight (not ideal)... If it could be set to terminate the auto run after say 10-20 errors of the same type I think that would be useful feature and, hopefully relatively easy to implement in the code..?
