How do you set the ADU value in the automatic Flat autorun. It exposes for the mid point on the histogram, and I would like it to be at the 1/3 point, instead of halfway.
billx Cannot do that, the AutoFlat uses 20k-40k range, so if you wanna 1/3 point which means 20-25k, you need to set the EXP time manually.
