While trying to shoot some flats with my ASI294MM, I discovered a bug in the camera at 1 second exposures. For example, while shooting my flats target at 0.5 Seconds I get and average output value of 20,400. Then setting the camera to 1 second exposure and expecting to get a value around 40,800 I get an output average of 59,156. This was using Sequence Generator Pro and the latest ZWO ASCOM driver. I also tried it with SharpCaps native driver, and ASI Studio and I get the same behavior. This graph shows the average output for exposure from 0.5-1.2. Something incorrect is definitely happening at 1 second as either the camera becomes more sensitive, or the exposure is wrong. This is with Binning set to 2X2.
I have a friend with the same camera and he has the same issue, so it it definitely an issue with the 294MM.
