I have an ASI224 camera ordered and want to know what the difference is between 10 and 12bit ADC? 10 bit allows much faster frame rates, but would I notice a difference between the two?
I will be using it primarily to photograph the ISS
Hello For the ASI224MC the 12bit ADC is the full bit mode 10bit ADC is the high speed mode,you can get higher fps in high speed mode
You can try the two modes in your photograph
