Sorry about that, her is a cut of the log, I am interested in understanding what the number sequence relates to after the Settling is complete, I am assuming time, and movement but not sure how to read into direction, axis, and the like. Thank you - Chris
Guiding Begins at 2021-02-05 21:01:15
Dither = both axes, Dither scale = 1.000, Image noise reduction = none, Guide-frame time lapse = 0, Server enabled
Pixel scale = 5.98 arc-sec/px, Binning = 1, Focal length = 100 mm
Search region = 50 px, Star mass tolerance = 50.0%
Equipment Profile =
Camera = ZWO ASI290MM Mini, gain = 110, full size = 1936 x 1096, no dark, no defect map, pixel size = unspecified
Exposure = 3000 ms
Mount = RainbowAstro RST/MC700GE-II, connected, guiding enabled, xAngle = -86.8, xRate = 0.462, yAngle = 177.8, yRate = 1.159, parity = +/-,
X guide algorithm = Hysteresis, Hysteresis = 0.100, Aggression = 0.700, Minimum move = 0.200
Y guide algorithm = Resist Switch, Minimum move = 0.200 Aggression = 100% FastSwitch = enabled
Backlash comp = disabled, pulse = 0 ms
Calibration step = phdlab_placeholder, Max RA duration = 2000, Max DEC duration = 2000, DEC guide mode = Auto
RA Guide Speed = Unknown, Dec Guide Speed = Unknown, Cal Dec = 68.8, Last Cal Issue = None, Timestamp = Unknown
Dec = 68.8 deg, Hour angle = -3.93 hr, Pier side = Unknown, Rotator pos = N/A
Lock position = 1605.882, 657.093, Star position = 1605.937, 656.603, HFD = 3.83 px
Frame,Time,mount,dx,dy,RARawDistance,DECRawDistance,RAGuideDistance,DECGuideDistance,RADuration,RADirection,DECDuration,DECDirection,XStep,YStep,StarMass,SNR,ErrorCode
INFO: SETTLING STATE CHANGE, Settling started
1,4.749,"Mount",1.017,-0.498,0.555,-0.930,0.350,-0.930,757,W,802,N,,,2142,32.60,0
2,7.305,"Mount",0.631,-0.254,0.289,-0.585,0.207,-0.585,448,W,505,N,,,2140,32.54,0
3,9.583,"Mount",-0.256,-0.071,0.057,0.264,0.000,0.000,0,,0,,,,2210,33.08,0
4,12.863,"Mount",-0.489,-0.094,0.066,0.498,0.000,0.000,0,,0,,,,2229,33.27,0
5,16.114,"Mount",-0.555,-0.128,0.096,0.568,0.000,0.000,0,,0,,,,2152,32.67,0
6,19.346,"Mount",-0.578,-0.095,0.062,0.586,0.000,0.000,0,,0,,,,2094,32.23,0
7,23.174,"Mount",-0.649,-0.226,0.189,0.675,0.000,0.675,0,,583,S,,,1990,31.39,0
8,26.364,"Mount",-0.294,-0.218,0.201,0.324,0.126,0.324,274,W,279,S,,,2124,32.45,0
9,29.025,"Mount",0.032,-0.116,0.118,-0.014,0.000,0.000,0,,0,,,,1886,30.58,0
10,32.305,"Mount",0.123,0.007,0.000,-0.122,0.000,0.000,0,,0,,,,1981,31.30,0
11,35.479,"Mount",-0.051,-0.039,0.036,0.056,0.000,0.000,0,,0,,,,2003,31.54,0
INFO: SETTLING STATE CHANGE, Settling complete
12,38.645,"Mount",0.010,-0.088,0.088,0.004,0.000,0.000,0,,0,,,,2012,31.59,0
13,41.902,"Mount",-0.050,-0.140,0.137,0.071,0.000,0.000,0,,0,,,,1959,31.14,0
14,45.116,"Mount",-0.153,-0.201,0.192,0.182,0.000,0.000,0,,0,,,,1836,30.13,0
15,48.969,"Mount",-0.276,-0.238,0.222,0.309,0.140,0.309,303,W,266,S,,,2170,32.78,0
16,51.855,"Mount",-0.208,-0.091,0.079,0.220,0.000,0.220,0,,189,S,,,1964,31.18,0
17,54.875,"Mount",0.035,-0.037,0.039,-0.029,0.000,0.000,0,,0,,,,1947,31.03,0
18,58.100,"Mount",0.195,-0.022,0.033,-0.190,0.000,0.000,0,,0,,,,1960,31.14,0
19,61.269,"Mount",0.114,-0.037,0.043,-0.107,0.000,0.000,0,,0,,,,1911,30.73,0
20,64.500,"Mount",0.066,-0.017,0.021,-0.063,0.000,0.000,0,,0,,,,1960,31.16,0
21,67.719,"Mount",-0.038,-0.183,0.180,0.065,0.000,0.000,0,,0,,,,1997,31.49,0
22,70.993,"Mount",-0.089,-0.110,0.104,0.105,0.000,0.000,0,,0,,,,1955,31.15,0
23,74.239,"Mount",-0.174,-0.087,0.077,0.186,0.000,0.000,0,,0,,,,2001,31.52,0
24,77.463,"Mount",-0.204,0.040,-0.051,0.196,0.000,0.000,0,,0,,,,1913,30.77,0
25,80.718,"Mount",-0.207,0.077,-0.089,0.193,0.000,0.000,0,,0,,,,1958,31.11,0
26,84.144,"Mount",-0.259,0.100,-0.114,0.241,0.000,0.241,0,,207,S,,,2076,32.05,0
27,87.108,"Mount",-0.111,0.161,-0.167,0.086,0.000,0.000,0,,0,,,,2158,32.73,0
28,90.376,"Mount",-0.148,0.186,-0.194,0.119,0.000,0.000,0,,0,,,,2081,32.11,0
29,93.641,"Mount",-0.082,0.154,-0.158,0.058,0.000,0.000,0,,0,,,,2175,32.87,0
30,97.337,"Mount",-0.270,0.194,-0.209,0.237,-0.132,0.237,285,E,205,S,,,2111,32.33,0
