Hello Steve
you can try set the output to Dew heater in ASIAIR app
you can change the voltage percentage(If voltage drop is ignored,the percent should be about 60,
12V*60%=7.2V)
Recommend test the voltage by the voltmeter firstly(hige voltage may DAMAGE the DSLR)
