The mount is powered on at home position, and ASIAir is syncing time and location from the app which displays both correctly when I start up. If I do a PA the AAP leaves my mount rotated 60 degrees West on RA. If I slew South and do a plate solve, it's happy with it and syncs that to the mount.
Then when I do a GoTo it's completely screwed up.
The only fix seems to be to power down the mount and AAP, manually return to home position, and power back up. Then hope it works.
As noted, it tried to rotate my RA axis beyond 24 hours. It should have at least realized that what comes after 23h59m59s is 0h0m0s, not 24h-plus. I supplied this information in hopes of helping ZWO find this bug.
There are lots of reports of this on social media. It seems like it may have been introduced with the latest firmware.
