And I don't understand why the Explore Scientific iExos-100 PMC-8 Goto connects to the ASI Air Plus but the Bresser Messier Exos-2 EQ GoTo does not. I mean they are both the same brand just a different product where is the problem?
Maagguuss The have different comm. protocols.
Hello ZWO I assume that the BRESSER Messier EXOS-2 EQ GoTo mount is still not supported therefore I would like to buy a new mount the Skywatcher Heq 5 pro. Can the ASI AIR PLUS be connected with an EQMOD cable or does this only work with the newer mount the SKYWATCHER HEQ5 SYNSCAN?
Maagguuss yes the EQMod cable is all you need. Synscan is just what Skywatcher calls its Goto system.
@PMTeam@ZWO any updates on this? Will the Bresser exos2 be supported in the future? Thanks in advance
Jerry158 Have not support it yet.
Tech@ZWO working on it?
Jerry158 Do not have such a plan yet, but I received a report from our user, he said it works with LX200 protocol. Did you try that?
Tech@ZWO it will not connect this way, I have the exos 2 with a serial to usb cable connected to the asiair mini, but I cannot select Meade lx200 classic. Would love if you made good software for Bresser exos 2 mount
Will try tonight, still waiting on mount to usb cable
Jerry158 Thank you for your test and support, i conveyed to our devs, they will consider in the future.
