Hi all. I have just received my ASIAIR Pro and I have problems using it in conjunction with SkySafari and my Vixen Starbook Ten controller. Here they are:
1.) As soon as I connect the mount in the ASIAIR app, the mount stops tracking and doesn‘t resume, even if I de-select mount control in the app. The only way to get it back up and tracking is to perform a power-cycle of the mount, which is of course not a real life option. FYI: The connection to the mount seems to work in principle; I can slew and goto.
2.) I am using a Lacerta MGEN2 for autoguiding and do not plan to use PHD2 built into the ASIAIR. Furthermore, I want to continue to use SkySafari for mount control. The latter works fine w/o the ASIAIR (i. E. With a dedicated portable router) but it DOES NOT work with the ASIAIR Pro connected to the mount. My setup:
- Starbook 10 connected to ASIAIR Pro via Ethernet cable
- iPad with SkySafari connected to ASIAIR hotspot
- SkySafari cannot find the mount under the IP address given by the SBT (and successfully used in the ASIAIR app).
- The SBT had the IP address 169.254.0.1 while my iPad was assigned 10.0.0.83 (different networks)
Does anyone have a similar setup and solve this problem, already? Might this just be a networking issue?
Thanks in advance for your insights.
Cheers, Georg
