I'd rather see Ethernet 10Gbps than more USB ... as USB speed goes up, max cable length get shorter and shorter. And then add all the usual USB issues (bandwidth sharing, more issue if there is a hub, bad USB controller on computer ...).
10Gbps ethernet (put 2 ports with LACP capabilities if you really need 20Gbps) allows for much longer distance without any issues.
