No as I image away from home. I have the WiFi extender that ZWO sells. It works well and the signal is very good. Downloads are also fast. However, I still get the problems highlighted above, I am not sure if it is because I did not use the PA function of the app. I cannot use the PA function as I live only 1.2 degrees north of the equator. the PA routine ends up moving the scope to below the horizon.
When the app tries to move it to the extremes of RA, these seems to be a sort of hard stop. Once it hits it , everything goes haywire and all the "synch" data seems loss and pointing goes off with the Goto. Otherwise, Goto is spot on. Not sure if it is something that has got to do with having the encoders.
