Hello,
I have a question about the use of the Mure Denoise “Scrip” from the Pixinsight processing program.
I have a ZWO ASI 183 MM Pro cooled camera and if for example I have shots made with gain 120 and offset 13.
I want to know if I should enter this data directly in the corresponding boxes of the Mure Denoise script or if I should transform them to other units.
I would also like to know where I get the parameter "Gaussian Noise" or if it can be calculated and how to do it.
Thanks.
