Guiding can be carried out successfully with an Alt-AZ mount (SkyWatcher Alt AZ Goto). Which parameters have to be set on the ASIAIR Pro for this?
hjnet DEC mode: Off
Thank you very much. All other settings Calibration Setup 1000ms, Max DEC Duration 2000ms, Max RA Duration 2000ms remain the same. If DEC Mode is Off, then DEC and RA Aggr. Are ineffective?
RA stills take effect.
