Please clarify the QE for both ASI6200MM and MC models. On your website and user manual you claim 91% for both models. Normally monochrome cameras have a higher QE than color due to no RGGB filter. For the crop sensor version (ASI2600) which uses same family of sensor from Sony, you show color camera QE as 80%. Even more confusing is that suppliers such as OPT here in US show both 6200 models with QE of 80%. Since this is an important performance metric for your flagship model, it is vital that this is correctly stated. Please clarify.
Also, whilst sorting out errors on your website, please clarify which models of camera the larger OAG are suited to. In some areas, it states ONLY can be used on the ASI6200, whereas elsewhere it says 2400 and 2600 models are also compatible, no then on your forum, you advise only 6200. This is very confusing. If I m to spend thousands on equipment, I really need clear and accurate information on your products. Thank you!
