Hello, Can I use a ZWO EFW with an ASI183mm mono? I don’t see how to attach it to the camera. Is the ASI813mm mono designed to be used with the manual zwo filter wheel?
TIA
Yes. The best solution of 55mm back focus length for your reference https://astronomy-imaging-camera.com/tutorials/best-back-focus-length-solutions-55mm.html
Thank you but I should have been clearer. What I meant to ask is how do you connect the EFW cable to the ASI183mm? Is there a splitter because I don’t see how to connect the EFW cable to the camera and still be able to connect the camera to the computer via the USB.
Thanks
Violetblue You can connect EFW to camera USB Hub.
Thanks , but the ASI183mm doesn’t have a usb hub. It only has one USB input. So how do I connect the EFW and connect the camera to to computer?
Violetblue So yours is 183 uncooled camera. Please connect your EFW and camera to computer seperately.
Thanks, Yes I was avoiding doing that. So I returned and bought the cooled version. Thanks
