To clarify further, I'd like to connect the phone to the mount-ASIAir Pro combo while keeping my pre-configured static LAN for the phone (or pc) the same and just configuring the ASIAir Pro with its own static IP that is something compatible within my existing network router's IP address range and subnet.
Connecting everything into this same router's IP subnet would allow me to control the mount and ASIAir Pro from several different pc's and tablets or phone's already on my current network.
I can workaround it if the ASIAir Pro can't be manually assigned an IP address and can ONLY accept DHCP IP assignment from a router. But was just wondering if the ASI be can be manually assigned an IP address or does it have to get it via DHCP from the router?
Thanks for your help and I hope this makes things a little more clear on what I'm asking.
Thanks,
Wade
