Hi! I've been having trouble with my 183MC for a while. It will show up as an available camera on any application I try it with (NINA, ASI Studio, SharpCap, etc). When I go to connect it will simply not connect.
With Nina I get the most information:
ASI_ERROR_GENERAL_ERROR
from call to ASIInitCamera(cameraId=1)
On Sharpcap it says it connects but drops all frames.
On ASICap it says 'Failed to open camera, do you want to rescan and retry?'
All my other ASI cameras work, I have a 1600MM Pro, 294MM Pro, 290MM, and 120MM.
I have tried it on different machines with no luck. I have tried with different cables with no luck.
The camera's USB hub does work.
