BigBobD I just got my ASIAirPro and powered it up, the wifi light blinks a few times and then goes out permanently.
There is a WiFi Reset hole right above the WiFi indicator. Give the reset a try using a paper clip, careful that you insert it straight in and not slanted.
If it still fails, try reflashing the microSD card using a blank one that is at least 32 GB in size.
The fastest way is to download a copy of the firmware, burn it into a new microSD card, and manually transferring the license.txt file in the BOOT volume from the existing card to the BOOT volume of the new card. Lots of info in this forum from users.
You can also try the new procedure of getting the license file by taking a QR code image on the ASIAIR and submitting to ZWO.
Once it works, be sure to back the microSD card up.
