Hello all, I need some opinions on what's going on with my camera. I recently picked up a used ASI183MM-PRO and I'm getting these light and dark horizontal lines. I've tried swapping out the USB cable, power supply, adjusting the USB limit, offset, gain, and even a different laptop with no luck. I know this sensor is prone to harsh amp glow, but these lines make me think the sensor is faulty. These lines only partially calibrate out, the final stacked image looks pretty bad. Any ideas on how to remedy this are much appreciated.
Image settings are:
Gain 111, offset 10, USB limit 80, 300s subs. Dark frames also included. Imaging SW was NINA.
