Hi all,
Very disappointed in the TWO ASIAIR PRO's I recently purchased adn they simply do not Work as required on the CGX.
The Mount will slew on it's on regularly.
It reads my GPS and ad's 180 Degrees.
You really NEVER know when the ASIAIR PRO is going to Slew the Mount and Where its going when it does.
Very VERY Dangerous and I see some "EXPENSIVE" damages from this ongoing ande well documented PROBLEM!
Is there anyone here that got a "Real" Answer from ZWO on a Firmware or software FIX?
The telling You to shut off your mount do a polar alignment start the mount, than start the ASIAIR (doesjn't work anyway and is a "NON_FIX Pathetic attempt at a Work-Around!
Any of "This Thing is GREAT Guys have a CGX and make with work without a NIghtly hour long Dance?
Does anyone know where you send this crap back to, I bought mine at OPT, Haven't contacted them as it's not a Problem that they should be able to Fix.
This is a ZWO Problem!
Am I Wrong?
Jim Jenia
Temecula
