Every time the mount dithers, I have to manually reconnect the guide scope. Evening else is normal operation. Asi2600mm asi290mm, mini guide camera, zwo efw, zwo eaf, asiair pro, pegasus power box, eq6r.
I replaced the USB cable for the guide camera. Problem solved.
