On the AIR v1 I,m having issues with the RA and Dec numbers/positions keep changing.
i,m or WIFI to an Ioptron CEM 26 mount. I,m connected through the WIFI to the Air and everything seems to be OK. Except that in the Mount screen it gives the mounts RA and Dec positions e.g. rA 6.42.09 Dec +89.50.44 everything fine as when I look at the Ioptron Commander (Ascom) and the handset they all say the same thing or thereabouts. However on the Air screen every couple of seconds the line showing the RA and Dec changes to 96.35.03 and 01.42.52. The lines on hand set and Commander stay the same . ? Then a second later it goe s back to the first setting a couple of seconds later it reverts back to the second value.etc etc. Any suggestions.
