Hello,
I have a problem to connect my ASI 385 to PHD2 for guiding.
I have also an ASI 294MM for the main camera. When the two cameras are connected to the computer, and I try to connect the ASI 385 to PHD2, PHD2 only recongnizes ASI 294MM (and connect it) instead of ASI 385, even if ASI 294 is already connected to an other software (NINA)...
I tried all the drivers (ASCOM1, ASCOM2, ASI camera) but I don't find how to select only the ASI 385.
Do you have a suggestion?
Thanks
