Hello all,
I just got an ASI1600mm Pro from another user on Cloudy Nights. I was collecting some dark frames using N.I.N.A. and after about 20 frames, I got an error that the image couldn't be downloaded. I closed that error and it continued to the next frame. The next showed the attached image. I closed the camera and disconnected it.
I was running 120 seconds, 61 gain, 5 offset at -15c, cooler power was at 70% (probably since it was inside).
connected with a USB 3.0 cable directly to the USB 3.0 port on my desktop and powered by a 12v 5a power supply. I made sure all of the drivers and software were up to date.
Has anyone else seen this type of pattern? What could cause it? Any solutions to not being able to download images?
