There were some older posts about this, and I know it can be done, but just wanting to confirm which holes you used. They all line up with the bracket nicely, and the focuser lock knob hole is a good candidate to attach. I would like to use one of the other two holes on the coarse focuser side, but what do those little Allen bolts do screwed in there? I don’t want to take one of those out and suddenly screw up something with the focuser. Anyways, for those of you that have done this, let me know exactly which ones you used. I know I have the option of using the lock hole so if that’s only one I can use then maybe that will work. Thanks everyone.
GM
