On an ASI294mc, IS THE SENSOR WINDOW filtering IR or UV? I am going to assume NO so an external IR/UV cut fioter might be a good idea?
That is correct, unless the spec has changed from the ASI294MC Pro I used to have, the window is AR coated only so an external UV-IR cut filter can be a good idea.
