Hallo Gert,
Sounds like a cool project. You may want to consider putting 2" R, G, B, Ha, OIII or SII filters in the slider. That would be really cool on the Milky Way 🙂 Plus you won't need the UV/IR cut filter. Note that using an ASI2600MM will yield monochrome images and the only way to get color images would be to use a combination of those filters.
Wouter
