While it’s technically accurate that the AAP only issues a new goto and it’s up to the mount to choose how to handle that command (flip or not). The issue is he has an EQ6-R Pro which works best when the mount is set to “FORCE FLIPPING”, this setting is a one-time setting each night, and therefore the AAP should be setting the mount correctly before issuing the new goto command.
So to sum it up - it’s the AAP fault flips fail by not correctly configuring the mount, thus causing failed meridian flips.
This is same for Celestron mounts, where it should be set to “Meridian - Favor West”, the default is to NOT flip, so when a goto is issued the mount doesn’t move because it thinks “I can still see it, I’m staying right here”
the AAP is responsible for configuring the mount to support proper flipping, today it doesn’t do that
