Hi,
For imaging with the ASI2600MM I need 3 more devices. Focuser Filterwheel Guider camera
The ASI2600mm has 2 usb ports. Is it OK to use mini usb hub/splitter to make one extra usb port? Example : https://www.amazon.com/dp/B07Z5TJDLW Data rate and power will not be a problem.
Please confirm?
Thanks, Gert
We recommend to use hub on PC/ASIAIR Pro. You can give it a try with mini hub on 2600, but we can't guarantee its stability.
