I have the 294MM-Pro, which is a very nice camera. If you are using ASIAIR PRO then it is a simple matter of selecting Bin1 mode to unlock the higher resolution. Bin 2 mode is the standard mode. Don't forget to select the mode you want if setting up an autorun.
I've not used it with other software, but would imagine it is similar.
