Hi guys,
Impressed as can be so far with the latest version.
Noticed a couple of bugs so far however ill raise those over in the bugs section, but there are workarounds and loving the multistar guiding and other latest features. One thing that I thought could hopefully easily be improved upon was the GoTo feature from a saved image. Whilst that does work pretty well, its not accurate enough for me, meaning the tolerance could be lowered to be very precise if possible. Noticed that going to the same location goes very close, but not perfect, and if its too far out then when you process later, youll end up having to crop borders of the image and sometimes its not a small amount that gets lost. Long story short, if there is a way to make that more precise that would save me about 30 mins of doing it manually in the field, and i would be grateful. Keep up the game changing work!
