How close can you get to the pole before your instrumentation hits the base of the fork? If you can get past +60º north (for example, Dubhe), you can use ASIAIR's polar alignment tool. You do not need to be at +90º declination to do polar alignment in ASIAIR; you can be up to 30º in declination away from the pole.
But be very careful. Your set up is an accident waiting to happen -- even when not doing polar alignment near the pole. With a wrong GOTO path (which happens often in ASIAIR if you frequent this forum), you will destroy both your camera and fork, and most likely the OTA's visual back, too.
Defork it, and mount the OTA on a German mount. You eventually will be forced to anyway, when an accident happens; at that point, your OTA may not be salvageable.
You might also check if the FOV of your combination is not too narrow for ASIAIR to do a plate solve. ASIAIR needs to plate solve during the polar alignemnt process.
