I am interested using my 533 camera with my Jetson Nano. Is there Linux software that works with the 533 and runs on the Jetson Nano from NVidia?
I’m not familiar with the board but perhaps Ubuntu 20.04 and KStars will run on it. It depends on whether the board supports armv7l or armv8. See
https://indilib.org/download.html
for installation instructions.
HTH, Wouter
The Jetson Nano and Xavier use the NVidia flavor of Ubuntu 18.04 for aarch64 so you need a 64 bit arm version of the astronomy software. ASI Studio seems to only be available for Linux X86_64. I have a special version of TheSkyX for arm64 and that runs on the Jetson and works with my ASI174MC-Cool. If ZWO release an arm64 version of ASI Studio that would be great for planetary imaging with a Jetson or Xavier. I don't use INDI so I can't comment on that part.
Rodolphe
rpineau Is TheSkyX for arm64 available for purchase? Also isn't the ASIAIR PRO running on an ARM processor?
Thanks for all the replies so far!
I agree that an arm version of ASIStudio would be great.
ZWO create arm drivers for their hardware which are used by INDI. So if the drivers work then INDI should work and KStars too.
wvreeven well I have a Jetson Nano, and a 533. So I guess I can test this. Where do I get INDI and Kstars from?
Yes, ASIAir Pro runs on arm and it uses the same arm drivers I mentioned before. But you cannot install the ASIAir Pro software on another device than ASIAir Pro.
I did a search and had no luck with an arm version of thesky.
Relativist See the link that I posted in my first comment.
wvreeven thanks, holiday weekend coming up, so I’ll try and give it a shot.
There is an arm 32 bit version of TheSkyX that is available for purchase (For Rapsberry pi and other ARM SBC running a 32 bit userland distribution). If you go to this page you can chose your OS : https://www.bisque.com/product/thesky-imaging-edition/ ARM 32 bit is in there (Linux ARM_32).
The arm 64 bits version of TheSkyX is not yet available outside of TheSky Fusion. It will be available at some points for the general public.
